Short Beep Tone with LM555
Belteshazzar
Joined Mar 16, 2010
34
Could someone help me finalize this project of mine?
I have found several beep circuits using the 555 but none to do what I need.
Attached is a schematic I found earlier, placed by Bernard and/or Sgt Wookie if I am not mistaken.
It works great, I played with the resistors turning R1 to 10K and R2 to 47k and it turns into a nice constant short beep alert tone...in case anyone is interested to build it.
I built it without the 2N2222A, just the right side of the schematic feeding it 5V.
Can I change this circuit somehow to do the following?
- Pressing a momentary push-button I get only a short beep that terminates after a fraction of a second EVEN if I keep the push-button pushed.
- Then, when you let go of the button and push it again its ready to do another short beep.....as quickly as I can press the button.
- Assuming the push button is NOT the also the power-on button; the 555 will be already on via a 5V supply.
....through a charge and discharge of a lytic cap maybe?
Belteshazzar
Joined Mar 16, 2010
34
Ratched, I'm sorry but I don't understand how to put it together, can you draw me a shematic using the 555 as one "one shot"?
Bill, I went through your circuits, I didn't see one that does what I described!
Maybe it was right in front of me, but I don't know how to recognize the circuit and/or make modifications to my specs!
Can you draw one up?
Wendy
Joined Mar 24, 2008
23,798
The monostable is what you described. I'll show how to connect a pushbutton when I get a chance.
How long do you want the beep to last?
Belteshazzar
Joined Mar 16, 2010
34
Thank you, Bill, it works PERFECTLY. This is exactly what I needed.
I changed the 10uF lytic cap to a 2.2uf to get a shorter beep, though.
I do have a problem, however, trying to find what pizzo speaker works with this circuit.
I only have one pizzo element that I found in another electronic gadget of mine and I don't know exactly what it is or where to buy it.
I got lucky and plugged it in the circuit I posted and it worked...it also works with your circuit.
I do not want to get lucky and 'happen" to find a pizzo that works.
I would like to have it fully identified and know where to buy it in case I want to duplicate this circuit.
The pizzo I have that works is labeled "WST-1206UX". There is also a "-P" and the + symbol. Its resistance is 175M.
The two giants, mouser.com and digikey.com don't have it.
Beforehand I had ordered a few pizzos from Mouser and nothing worked, only this one that I found laying around.
What is the 'Sonalert'. I have seen this posted on other projects too.
Does it have a built in oscillator?
Do you have a part# so that I can buy it from mouser or digikey?
Thanks again for the circuit!
Belteshazzar
Joined Mar 16, 2010
34
Never mind....I found the info.
It's a regular piezo buzzer 3V-12V. Has the drive built-in. Just give it power and it sounds.
Thanks again for everthing!
