Hi all,
I am in the process of building a PWM MOSFET slot car controller. My 'control' stage works fine and now I am on to the 'power' stage. The 'control' stage is to send a 10kHz PWM signal to either the 'drive' or 'brake' FETs via an L6387E High & Low-Side FET Driver. The L6387E contains an internal Bootstrap Diode which charges an external Bootstrap Capacitor for the High-Side Driver (Throttle). As most of slot car racing is performed at full throttle (ie 100% duty), the Bootstrap Capacitor would quickly lose its charge. Would my circuit in the attached file be the correct way to connect an external Charge Pump (555 Voltage Doubler) to the L6387E, to keep the Bootstrap Capacitor filled during the 100% duty stages? Do I even need the Bootstrap Capacitor if I use an external charge pump?
Any feedback would be greatly appreciated.
Ken
L6387E: http://pdf1.alldatasheet.com/datasheet-pdf/view/242080/STMICROELECTRONICS/L6387E.html
Ken
