Hey guys attatched is the test schematic from IR and some notes of the problems i am having with the IR2101..
I need some help in getting it to work. I cant even get the test circuit to work.
can someone explain how i need to calculate the proper capacitance and diode values it would be ace too.. But most importantly a proceedure and circuit would be much appreciated. I have another little DC motor that i have been using as the load to test this. I am also sending the pulse to the HIN and LIN from a micro, or function generator.
the IR2101's are intended to be used in a full bridge inverter to cotnrol a BLDC, pulsed from a PIC micro controller.
cheers:
cheers:
