Hi again,
I have an alarm clock that is too bright at night. I want to use an LDR switching circuit to automatically dim it at night time. However, first I need to find the best way to do so. I have identified the driver chip for display/clock to be a LM8560 and have found a datasheet on it. It is designed for use with a common cathod Duplex LED display which has two connections for cycle-1 and cycle-2 connection to AC power.
If I just used a resistor in each cathod connection to 0v, I suspect that the individual segments on the display will dim unevenly. So, I intend to make a dimming circuit like this one: http://www.reuk.co.uk/OtherImages/ne555-pwm-led-dimmer-circuit.gif
I am unsure whether this will be suitable for PWM of the cathode connection to AC?
Thanks for any ideas/advice.
