Hi there.
I am new to this forum and not sure if this is the correct place to post?
I got a 230Vdc treadmill motor with no controller.
I bought a 4000w speed controller from amazon 230Vac to 230Vac with a bridge rectifier.
I connected the speed controller to the mains and the outgoing terminals to the bridge rectifier then through a choke then to the motor.
My problem is when I turn on the power the motor start straight away and the potentiometer is turned completely left.
When I turn the potentiometer clockwise the motor RPM increase.
As far as I know if the potentiometer is turned completely to the left the motor should not start when the power is turned on it should only start when you turn the potentiometer clockwise.
The speed controller got a 500K potentiometer.
I also tried 2 speed controllers and both doing the same can someone please help?
Regards
Johannes
Regards
Johannes
