Photovoltaic model LTspice - shading scenario simulation
Hi people,
I am a researcher in a university and I've been investigating solar panels and the latest area that the group is exploring is related to shading scenarios and the behaviour of arrays with different connections between modules (Series, Parallel, Series-Parallel, Total-Cross-Tied, etc) also diving into the reconfiguration of the array to further reduce the lossses.
I've been tasked with the development of an relatively easy way to check how good are the reconfigurations and so I though about LTspice as a easy program to test circuits and since I had some experience in it it seamed like a good idea.
I've been using this solar panel model (files bellow):
Everything works fine (n is multiplied by 5 because my module has 5 cells in series) but when i add multiple panels and try to simulating shading scenarios sometimes it gives me the wrong results. I've tested these scenarios with an array with real solar panels in a solar simulator that's why i am sure they don't work correctly.
