Make With Mouser IoT Design Contest
After 1 month I was received the Microchip Technology SAM-IoT WG Development Board from All About Circuits.
I just realized this board is so amazing board with many benefit when using with Google Cloud. And easy to study the Google Cloud IoT service from Google.
So I decide to test all the example and try to integrated it with all the Google Cloud IoT Core service such as:
1. Streaming IoT Data to Cloud Storage.
2. Streaming IoT Core Data to Dataprep.
3. Building an IoT Analytics Pipeline on Google Cloud
4. Using Firestore with Cloud IoT Core for Device Configuration.
I did successful all these task and learn a lot from this board and google cloud IoT service. Learn how to configure Cloud Functions for Firebase to relay document changes in Cloud Firestore as configuration updates for Cloud IoT Core Devices.
Beside that I also using another M5-Stack ESP32 module together with SAM-IoT Board and found out the benefit of SAM-IoT Board have ATECC608A CryptoAuthentication™ secure element IC. It make the project more professional and more secure if we want to develop the whole complex IoT system for Customer or Commercial purpose.
Using SAM-IoT Board have ATECC608A CryptoAuthentication™ secure element IC with Google Cloud IoT Core service bring you the best secure system and more professional like this diagram:
I start to study and design my IoT system base on this Infrastructure :
The example from Microchip to Google Cloud is not update so it not working and get many error, It make me 1 week to figure out how to connect the SAM-IoT Board to Google Cloud IoT core.
So I make a clone of Microchip example and modify some update lib and it work very well and also can use together with M5-Stack ESP32 module.
This is the link of my GitHub : https://github.com/johnnietien/microchip-pic-iot
So far what I can do is basically can using the front end React apps to show the real time data from device of SAM-IoT Board and M5-Stack ESP32 module:
At beginning I have to research and master the way to connect all the device to Google Cloud IoT Core: Create and Register the Device by Authentication method with or without the ATECC608A CryptoAuthentication™ secure chip.
Then learn how to save the data with cloud storage. And learn to use Cloud Function to store data to Realtime database in Firestore. And also learn how to use DataFlow service from Google to trigger automatic storing all the data from Cloud Pub/Sub Topic. And The final step is using Dataprep service to modify the data more clear and easy to use. All this pipeline is very helpful in design a professional IoT system for my project.
from now I can have basic infrastructure of my Iot system.
My next step is design the PCB sensor board to plug into the SAM-IoT board by mikroBUS header. I still consider doing a new sensor board or just find and buy MikroElektronika click Boards™
I will update the progress in next post.
