i have zvs flyback driver and taking up to 2000 voltage on secondary side with around 100 turns on secondary coil . no any problem
but something strange happening , if i add more turn ( in order to get higher voltage ) on secondary winding ( above 100 turns , ie 300 turn ) there is absolutely no voltage on secondary side although good oscillation and good voltage on primary .
core is ferrite from old CRT tv and i rewinded , i also have tested on sendust toroidal core , but same
pls advise , what is going wrongly
