Zero-Crossing Detector problem
Se7en Axis
Joined Jan 10, 2019
10
Greetings everybody,
I am experiencing an issue with the zero-crossing detector, I use a 4N35 to send a signal to my arduino at every zero crossing of the AC to control a load, the issue is everything works 100% fine while the arduino is wired to my PC, but once I disconnect the USB and instead use the 5V supply I have to power the arduino the zero-crossing detector doesn't seem to work, I don't have an oscilloscope to check the pulse but with a multimeter i get abnormal voltage between the ZCD pin and ground flickering between 350mV to 450mV while when it's plugged in I get a steady 500mV and does trigger the triac as it should, so could the supply be bad? it does output 4.85V DC but I noticed it also outputs 400mV AC despite having the smoothing capacitors.
It's also worth mentionning the arduino seems to power on properly on the 7805 supply, I can still trigger the triac but I get nothing from the zero-crossing detector however.
Schematic information:
U1 = 4N35 U2 = MOC3021 U3 = 7805
It's worth mentionning I have added a diode before R1 to separate the 120Hz unfiltered signal from the powersupply or else it wouldn't work, I also removed R11.
Se7en Axis
Joined Jan 10, 2019
10
yes I do my apologies I forgot to include that in the schematic as well, it's going from the output of 7805 to 5V in of my arduino mega
Se7en Axis
Joined Jan 10, 2019
10
I was just out of ideas and desperately added another 0.1uF capacitor between the 5v and gnd and what do you know now it works, what in the actual there was already a 0.1uF at Vin of 7805 and a 0.33uF at Vout of 7805, adding another 0.1uF at Vout of 7805 (gnd and 5v pin) fixes it??? what the heckers
drc_567
Joined Dec 29, 2008
1,156
... breadboard? Occasionally the wire sockets don't make good contact ... not enough tension, a little dirt or corrosion on the wire ... who knows.
... This circuit looks like something that an oscilloscope might be appropriate for. The interesting aspect is that jt has AC and DC constituents. Sometimes that presents a problem. ... Just saying ... if you ever get a,scope, see this video first in order to avoid any surprises.
... posted sometime today, as I recall.
Sensacell
Joined Jun 19, 2012
3,787
Your Zero Crossing Detector scheme makes little sense to me.
The voltage regulator U3 will be dropping out every cycle, due to the tiny little .33 uf cap on the input.
The opto isolator is totally unnecessary as the output side shares the ground- it provides no isolation.
Since your transformer provides the isolation, why not just connect one leg of the transformer secondary to ground, then connect the other leg to the MCU through a 100 K resistor? The input protection diodes on the MCU will clamp the signal between the rails.
120 uA into the input protection diodes will be fine.
R11 makes no sense? that's a schematic error, right?
You can eliminate 50% of the parts.
Se7en Axis
Joined Jan 10, 2019
10
Thanks for the replies, the circuit is on a PCB already therefore the connection issue would of been out of question as the soldering is ok, I have to agree 100% that the oscilloscope would of made it so much easier, I am still baffled as to how adding a secondary capacitor to the output would of fixed the issue, especially as the AC on the output still is 400mV.
Se7en Axis
Joined Jan 10, 2019
10
Thanks for replying,
Do you suggest I should remove the .33uF capacitor on the input therefore? I am a little confused as to how this would cause the 7805 to drop
after each cycle, I thought the input/output capacitors were simply to prevent oscillating/reduce ripple therefore the values wouldn't be that important(0.33 and 0.1 seemed like a standard on most 7805 datasheets)
And indeed the R11 resistor was a schematic error my apologies for making this more confusing than it should be.
I am unsure as to how the optoisolator could be removed, just to clarify you are talking about U1 (4N35) or U2(Moc3021)?
ericgibbs
Joined Jan 29, 2010
21,554
hi s7,
One problem could be fixed by:
Add a diode in series from the bridge output to the 0.33uF cap.
This will isolate the smoothing effect of that cap it is having on the Opto emitter, where you need a clean full wave rectified waveform.
Add a 470uF in parallel with the 0.33uF, this will give a smoothed Vdc input the regulator.
E
Also add a 470R across C3 cap to ensure a least a 5mA load current, keep the Vreg loaded.
Sensacell
Joined Jun 19, 2012
3,787
U2 is essential, it isolates the low voltage portion of the circuit from the AC line.
U1 does not serve any useful purpose as connected- eliminate it.
Following that logic... the regulated DC power supply seems to power only the U1 circuitry, if you ditch U1, then you can eliminate the entire power supply- EXCEPT for the transformer, as this provides needed isolation from the AC line.
You can use the transformer output voltage direct into an IO pin for ZCD functionality, just use a large value (100K) resistor to protect the input.
The input protection diodes will harmlessly clamp the excess voltage.
ericgibbs
Joined Jan 29, 2010
21,554
hi s7,
This is LTSpice sim of the front end of the ZCD circuit with the diode and resistor mods.
It has not been optimised.
E
Added a plot without the mods, for comparison
cmartinez
Joined Jan 17, 2007
8,854
Here's the best zero-crossing detector circuit I've seen so far. It's extremely reliable and simple. It was designed by someone who's webpage, sadly, no longer exists. And yes, I've actually built and tested the thing, and it works perfectly.
schmitt trigger
Joined Jul 12, 2010
2,208
I have also used the circuit posted in #12, it really works well.
Additionally, what is the part number for phototriac U2? Even the most sensitive variants, like the MOC3012 or MOC3023, require 5 mA to trigger reliably. Other variants require up to 30 mA.
And your 5 volt Arduino output, minus the LED's forward voltage drop (1.5v), divided by 1k can't provide 5 mA.
MrAl
Joined Jun 17, 2014
13,784
Also beware the opto input LED voltage drop combined with the bridge rectifier voltage drops will cause the zero crossing to actually be about 10 degrees off. That may be too much or you might get by with that.
