Zero crossing detector
ANOUXR
Joined Mar 1, 2020
6
I want to use a zero crossing detector on my projet, i need help about the value of R1,R2 so i cant dammage the bridge (2W04G) and the optocoupleur(4n25).Im new to electronics so i have some issues on reading datasheet.
LesJones
Joined Jan 8, 2017
4,536
As the maximum IR emitter current rating is 80 mA I suggest limiting the current to about half this value. So R = 230/0.04 ohms = 5750 ohms. This will be the sum of the two resistor values. So making each resistor 2.7K should be about right. The total power dissipation in the two resistors will be 230 ^2/5400 = 9.8 watts. So each resistor will dissipate about 5 watts. I would choose resistors with 10 watts rating. The forward voltage of the IR emitter can be ignored.
Les.
ANOUXR
Joined Mar 1, 2020
6
Les.
Ok thank you so much.
LesJones
Joined Jan 8, 2017
4,536
Hi Dick, I agree. I chose the high current so that the zero crossing pulse would be as short as possible with that design of detector. Like many request for help we are not given the full picture. Depending on the TS's requirement it may be possible to use higher value resistors. (Or a different design of zero crossing detector may be a better solution.)
Les.
AlbertHall
Joined Jun 4, 2014
12,652
The transistor in the opto only needs to be able to sink 0.5mA (5V, 10k) and from the datasheet a diode current of 10mA should be sufficient and that makes the resistors 12k and the power in each would be 1.2W.
LesJones
Joined Jan 8, 2017
4,536
Hi Albert, As the minimum transfer ratio is 20 % then you would only need 2.5 mA through the IR diode for the photo transistor to sink 0.5 mA As the peak voltage of 230 volts RMS is about 325 volts the peak current current with 24K would be about 13 mA 2.5/13 = 0.19 so SIN^-1 of 0.19 is about 11 Deg. So the transistor would not be fully conducting fo about 11 degrees either side of the zero crossing. The TS will have to decide if this is enough for his requirement. Even the values I chose may not give a short enough zero crossing pulse for the TS.
Les.
ANOUXR
Joined Mar 1, 2020
6
Les.
I want to use it for dimming a halogen lamp (220v ac)
DickCappels
Joined Aug 21, 2008
10,662
Perhaps it would be better if we advised ANOUXR to use a different optocoupler or a different circuit (perhaps at ci139 suggests) if he wants to get by with a lower power dissipation.
Dimming an halogen lamp usually does not require a lot of timing precision.
ANOUXR
Joined Mar 1, 2020
6
I want to control a halogen lamp using triac (Q4010L5) and optocoupleur (MOC3021).
I want to know the best value for (R1-R2-R5), to not dammage the triac and optocoupleur.
"I didnt mention here the zero crossing detector part that will give implusion to RB1".
BobaMosfet
Joined Jul 1, 2009
2,211
