Any time you don't have the right zener - there's always the TL431.I have some parts ordered to breadboard the original idea, of all things i did not have the correct zener lol, I need to keep this as small and cheap as possible, the items im making are only sold for about 20 bucks each and to keep that price i need the power items to be about 3 bucks max, im not making them in bulk so i cant get a good price on some of this stuff.
Basically it will power an ATtiny45, two 5 volt relay coils and a small 3mm led, in actually thinking about it it will only have to power the ATtiny and one of the other items at the same time, I could really get away with about 40-50 mA of power.
The other circuits i have looked at have capacitors going from just after the resister to ground with a 104 0.1uF cap, what would this be for?
Sometimes listed as a "programmable zener" its actually a comparator with built in 2.5V Vref, in use, you roll the comparator off with a lot of nfb to put it in linear operation, the cathode terminal feeds a voltage divider with the tap to V-in.
There's a wealth of datasheets & appnotes online to tell you all the nitty-gritty details - and if you search hard enough, some crafty little tricks that aren't in the appnotes.
