Zener Diode Power question
alanj100
Joined Apr 26, 2019
22
SMD 5V6 Zener diode, The Zener diode I have chosen is a 5v6. The diode has an absolute max rating of 300mW.
If a dc level of 12V is put across it I get a power of 273mW across the diode.
So my question is will the Zener get too hot and burn out if I leave the 12v on it for some time
Papabravo
Joined Feb 24, 2006
22,111
The devil is in the details. Show us the schematic diagram of what you are talking about. The information you have provided so far allows me to answer: "probably not, but maybe yes -- eventually". I'm guessing that sort of prevarication was not what you were looking for,
alanj100
Joined Apr 26, 2019
22
All we have is a 150R resistor and 5V6 Zener in series connected to a single gate xor chip. The max voltage of the chip is 6V6 volts. I just want to protect the chip incase someone accidently applies 12V rather than 5v
alanj100
Joined Apr 26, 2019
22
The chip is M74VHC1GT86DFT1G. The problem with such a large value resistor is the current may well not be enough for the zener to conduct even if it goes above the max 6v6 volts
Alec_t
Joined Sep 17, 2013
15,156
In that case the 1k resistor Bob suggested will be fine. The current through the Zener will be ~(12V-5.6V)/1kΩ = 6.4mA, which is good.
alanj100
Joined Apr 26, 2019
22
The problem I have is at 12v it would be fine but at 8 or 9 volts the current may well be too small for the diode to conduct
Papabravo
Joined Feb 24, 2006
22,111
I ask for a schematic and you give me another bit of "word salad" that is open to varying interpretations. Once more with feeling: "there is just no substitute for a for a complete schematic diagram".
38,822
A resistor in series with the gate, with a Schottky diode from the gate input (anode) to +5V (cathode), will also protect the input from overvoltage.
35,185
You have not made it clear.
What is the 5V or 12V feeding?
Is it an input pin or Vcc of the 74xx gate?
28,310
A zener diode shunt regulator is terribly inefficient, except as a heat source. And, like all diodes it is very non-linear. The voltage regulation improves as the current increases, and at lower currents the voltage will be higher than the rated voltage. So for battery operated systems the zener is a poor choice for regulation . To protect a logic gate, where under normal conditions the zener will not be conducting, is reasonable. MY suggestion is to have the series current limiting resistor to be the lowest wattage available, so that in the event of an excess voltage being present for an extended time the resistor will fail open, and the gate will be protected.
alanj100
Joined Apr 26, 2019
22
A zener diode shunt regulator is terribly inefficient, except as a heat source. And, like all diodes it is very non-linear. The voltage regulation improves as the current increases, and at lower currents the voltage will be higher than the rated voltage. So for battery operated systems the zener is a poor choice for regulation . To protect a logic gate, where under normal conditions the zener wioll not be conducting, is reasonable. MY suggestion is to have the series current limiting resistor to be the lowest wattage available, so that in the event of an excess voltage being present for an extended time the resistor will fail open, and the gate will be protected.
Thanks , that is exactly what I thought
28,310
Another option that I have used is called "Diode Clamping", where there are two diodes in series invese across the 5 volt supply, annd the signal is tied to the junction of the diodes. So if the signal rises above the supply the top diode willconduct and prevent it from exceeding the supply by much. And if the input goes negative, the bottom diode will conduct and prevent the input from going far negative. This method does require a series resistor to limit the current, though. A one Kilohm resistor will usually be adequate.
