Zener Diode Circuit: Load regulation
pythagolivia
Joined Sep 20, 2017
5
I tried I(load) = I(I) = ( V(PS) - V(Z) )/Ri
using V(PS) = 14V and V(Z) = 9V
So I got 312.5 mA for no load I(L).
Not sure where I should go from here.
pythagolivia
Joined Sep 20, 2017
5
The diode is reverse-biased, so Vz should remain approximately constant at 9V, right?
Do I just work with the average Vps = (14+12)/2 = 13?
So the Voltage drop across the resistor should be
Vs = Vps - Vz
= 13 - 9
= 4 V
And Ii = 4/16 = 250 mA
At no load, I(Z) = I(i) = 250mA because of the open circuit
Then at full load, I(Z) = Ii - IL = 250 - 100 = 150 mA
Then load regulation = (250-150)/250 = 40%
Does this make sense?
dl324
Joined Mar 30, 2015
18,491
Is that what you were taught to do?
I'd do the calculations once for each combination to determine the worst case conditions. Or you can think about it and only do the calculations that would give worst case results; which is what you want if you're going to calculate load regulation.
pythagolivia
Joined Sep 20, 2017
5
Thanks! I think you're right.
WBahn
Joined Mar 31, 2012
33,324
The first thing you need to do before you can calculate load regulation is be sure that you understand what the definition of load regulation is. What does it tell you? What information do you need to calculate it? Given that information, what is the actual calculation that needs to be done?
