Hopefully there are some Z8000 experts around...
A few years ago there was a post about an undocumented connection on the Z8000 CPU, which must be on the only NC/Reserved Pin on the Z8001 (pin 33). Unfortunately I can't find anything about it, although I am curious because on the Z8003 the pin is used to support virtual memory.
Also, I recently acquired a bunch of Z8001 and Z16C01 CPUs from different vendors:
All the NMOS CPUs and the CMOS CPUs with the Zilog logo (Date code 9450, below) work perfectly. The CPUs with the Z (Date code 9834) seem to crash in a strange way, as if they disconnect from the bus without signaling it on the BUSACK line. Any idea of what this could be? Is it a bad batch, or are there some real differences?
Thanks a lot!
Does anybody have any idea on what it is?Historically, the convention held that 'NC' (not connected) meant there was no connection to the die -- whereas 'reserved' meant 'leave it alone' (i.e. floating) ostensibly to assure 'backward compatibility' of future versions (albeit there were a good many 'undocumented connections' bearing that designation -- the Z8000 CPU series comes to mind) --- Unfortunately the convention failed to become standard and all bets are off -- that said, I concur with @crutschow - either ground it of leave it untied but under no circumstances 'count on' the untied pin to be merely floating...
Best regards
HP
Thanks a lot!
