YAMAHA ORGAN MOD
J_gally
Joined Nov 24, 2020
Hello all. I have a Yamaha electone mc600 organ, I want to mod it so I can play guitar effect pedals with it and via its internal speakers not external ones I I also want to connect them so the drum machine aspect of the organ is not effect by the guitar effect pedals. I have attached a link to the service manual which has block/schematics Diagrams. Any help/advice is deeply appreciated. Thank you all, enjoy
https://m.box.com/shared_item/https://app.box.com/s/k82zc7xq4233mk354ljt
Wolframore
Joined Jan 21, 2019
2,619
Does the onboard effects it comes with (such as reverb) affect all the channels including the drum machine? You have to find a point where they are divided. I can't tell which VCA is which in the block diagram. You need an insert point.
I'm guessing he wants to use use things like distortion and echoes.. etc.
absf
Joined Dec 29, 2010
1,968
If you just want to mix the audio output from you guitar effect and that of the organ outputs, it should be possible. By connecting the output of the guitar effect pedal to the aux jack of the organ.
The main volume control would amplify both the audio of the guitar and the organ.
Wolframore
Joined Jan 21, 2019
2,619
I believe what he wants to do is what’s known as an insert, whI h inserts the effects into the signal chain but wants to isolate the percussion from the effects, it will take some surgery and identification of which circuits do what but it is possible.
