Hello
I have a speaker Ibiza XTM-12 AMP and my grandson has put the audio jack from the output cables in the white LINE in plug. (while plugged in mix out)
Since then the speaker doesn't work properly and by this I mean the volume, bass, treble can't be adjusted with the potentiometer. The speaker does work when I plug the audio jack in my phone and the volume can be adjusted only from my phone. The Mic1 and mic2 does work, I can adjust the mic volume and echo. When I play some music the resistors here are getting here is a picture click
I have made a few pictures to show you the electronic boards maybe can someone say what is probably wrong or give me some advise.
You can see all the pictures here
Many thanks
Mod edit: Its preferable to use File Upload to host images here. That way, the thread is preserved for future users. I have moved them for you.
Welcome aboard!
Many thanks
Welcome aboard!
