hello to everyone...!
I have made function generator circuit using XR2206 and it works perfectly with varying frequencies of 20Hz-20KHz.. But the the problem is that when i connect this function generator output to the input of AD620 (pin 3) having Rg=100 then there is no output at the pin 6 of AD620
whereas when i connected the same fucntion generator output to my low pass butterworth filter (Fc = 25 Hz) then its working as well as showing excellent frequency response.. I am just stuck here ... what's the problem with AD620...? ( my AD620 circuit is working fine when input is given by lab Function generators)
Thank u...
Thank u...
