It's been over eight years since my only PIC24 project and things have changed a bit since then.
I am using MPlabX to create an assembly program for a 24K32KA302. It took a bit of reading and digging to come up with a basic program as it is a bit different from MPASM which I thought I used last time. So far it compiles and the hex file looks about right. What I did find is it looks like XC16 will add certain "standard" code which I am curious if anyone knows what it is. I plan to program a disassembler down the road some time to figure it out, but now that I see the general idea it really is not that important. Unfortunately the list file MPlabX generates in the IDE does not show the "standard" code.
The program so far (the config is in a separate c file as suggested by XC16)...
Turns into...
_main: should start at 200, but there is some filler until 2ce and that is what I am curious about. The generated map file shows four additional sections between 200 and 2ce. I understand the default interrupt, but the rest...
Generated map file
and the resulting HEX (not the actual hex file, but a filtered view)...
the left column is the address in each HEX line added to the segment address stored from an earlier line. The address needs shifted right one bit to be the correct program address. 400 = 200 and 59c = 2ce
The rest of each line is the corresponding data from each data line in the HEX file
I know I am missing the stack setup in my code which it looks like that is probably a few instructions of the "standard" code since it is defined in the map file, but other than that I don't know.
At any rate thanks for looking.
Code:
.include "inc/global-defines.inc"
.text
.global _main
_main:
goto _main
Code:
--- /home/jason/usr/local/src/pic24f/24f32ka302-template/asm/main.s -----------------------------------
1: .include "inc/global-defines.inc"
2:
3: ;--------------------------------------------------------------------------------------------
4:
5: .text
6: .global _main
7:
8: ;--------------------------------------------------------------------------------------------
9:
10: _main:
0002CE 0402CE GOTO 0x2CE 11: goto _main
12:
13: ;--------------------------------------------------------------------------------------------
14:
15:
16:
17: ;--------------------------------------------------------------------------------------------
Generated map file
Code:
"program" Memory [Origin = 0x200, Length = 0x5600]
section address length (PC units) length (bytes) (dec)
.text 0x200 0xce 0x135 (309)
.text 0x2ce 0x4 0x6 (6)
Total "program" memory used (bytes): 0x13b (315) <1%
"data" Memory [Origin = 0x800, Length = 0x800]
section address alignment gaps total length (dec)
Total "data" memory used (bytes): 0 (0)
Dynamic Memory Usage
region address maximum length (dec)
heap 0 0 (0)
stack 0x800 0x800 (2048)
Maximum dynamic memory (bytes): 0x800 (2048)
Info: Project is using a large data memory model when small data memory model is sufficient.
External Symbols in Program Memory (by address):
0x000200 __resetPRI
0x00023c __psv_init
0x000252 __data_init
0x000252 __data_init_standard
0x0002c8 __DefaultInterrupt
0x0002ce _main
0xf80000 __FBS.sec
0xf80004 __FGS.sec
Code:
00000000 :: 00 02 04 00 00 00 00 00
........ there was some other data here that would map to interrupt vectors .....
beginning of program
00000400 :: 0f 80 20 00 0e ff 20 00 0e 01 88 00 00 00 00 00
00000410 :: 00 00 20 00 00 00 e0 00 02 00 32 00 00 01 20 00
00000420 :: 20 02 88 00 14 00 07 00 5b 00 07 00 00 00 e0 00
00000430 :: 03 00 3a 00 00 00 20 00 01 00 20 00 02 00 37 00
00000440 :: 00 00 20 00 01 00 20 00 81 0f 70 00 01 00 32 00
00000450 :: 14 00 07 00 00 00 20 00 00 00 e0 00 02 00 32 00
00000460 :: 00 00 02 00 00 00 00 00 ce 02 02 00 00 00 00 00
00000470 :: 00 40 da 00 00 00 fe 00 44 40 a9 00 00 00 20 00
00000480 :: 00 00 e0 00 03 00 32 00 00 00 20 00 a0 01 88 00
00000490 :: 44 40 a8 00 00 00 06 00 8a 1f 78 00 8b 1f 78 00
000004a0 :: 00 00 06 00 91 01 88 00 80 04 78 00 00 00 eb 00
000004b0 :: 1a 00 37 00 e2 84 44 00 32 a0 b4 00 99 05 ba 00
000004c0 :: e2 84 44 00 32 a0 b4 00 99 06 ba 00 e2 84 44 00
000004d0 :: 32 a0 b4 00 00 06 eb 00 47 6f de 00 fd 07 b2 00
000004e0 :: 63 6c e1 00 03 00 3a 00 eb ff 07 00 00 00 eb 00
000004f0 :: 0a 00 37 00 60 6c e1 00 04 00 3a 00 00 5d eb 00
00000500 :: 8b 05 e9 00 fd ff 3e 00 04 00 37 00 61 68 e1 00
00000510 :: 01 00 32 00 00 86 eb 00 0b 00 07 00 19 c7 ba 00
00000520 :: 19 05 ba 00 0e 04 e0 00 03 00 3a 00 0a 00 e0 00
00000530 :: e0 ff 3a 00 00 00 06 00 fe 07 b2 00 9e 01 88 00
00000540 :: 8a 04 78 00 f5 ff 37 00 39 5d ba 00 8b 05 e9 00
00000550 :: 0c 00 32 00 29 5d ba 00 8b 05 e9 00 08 00 32 00
00000560 :: 0c 00 e0 00 03 00 3a 00 e2 84 44 00 32 a0 b4 00
00000570 :: f5 ff 37 00 19 dd ba 00 8b 05 e9 00 fa ff 3a 00
00000580 :: 89 04 e8 00 e1 84 44 00 32 a0 b4 00 00 00 06 00
00000590 :: 00 40 da 00 00 00 fe 00 00 00 05 00
0000059c :: ce 02 04 00 00 00 00 00
01f00000 :: ff ff ff 00
01f00008 :: ff ff ff 00
01f0000c :: 7f ff 00 00
01f00010 :: bb ff 00 00
01f00014 :: 5f ff 00 00
01f00018 :: fb ff 00 00
01f0001c :: ff ff 00 00
01f00020 :: ff ff 00 00
