write cycle of eeprom
bug13
Joined Feb 13, 2012
2,002
Hi guys
I am looking at different eeprom, say this one for example:
http://www.atmel.com/Images/Atmel-8819-SEEPROM-AT24C01C-02C-04C-08C-Auto-Datasheet.pdf
It say 1M write cycle @ 25 degree C, that's pretty good.
But what is 1 write cycle?
Code A:
Code:
eeprom_write_one_byte();
Code B:
Code:
eeprom_write_one_page();
Code C:
Code:
for (uint8_t i = 0; i < 128; i++)
Code D:
Code:
etc...
12,127
A write cycle is the change in value of one bit, and this spec applies per bit. If you overwrite one bit 1 million times, but don't use some other bit at all, the first one will be running out of life and the other one will be as fresh as the day it was manufactures. This is why some flash memory devices and systems have what is called "load sharing". You think you are writing to the same location each time, but the system moves it around in memory to other unused locations so a small group does not get overused and shorten the long term reliability of the device.
bug13
Joined Feb 13, 2012
2,002
Hi guys
Just a couple more question regarding eeprom read/write cycle.
  • I don't see an eeprom datasheet states it's read cycle, and I read somewhere eeprom has unlimited read cycle, is that true?
  • In this 1G NAND eeprom here, it doesn't mention any erase/write cycle at all, what is the normally expect write cycle for these memory? I am under the impression that these type of memory use different mechanism to deal with write cycle, if that's the case, what is it?
Thanks a lot guys!
dl324
Joined Mar 30, 2015
18,326
Yes
this 1G NAND eeprom ... doesn't mention any erase/write cycle at all, what is the normally expect write cycle for these memory?
All NAND FLASH have array defects and you must use error correction to insure data integrity. Wearout is spec'ed differently for NAND than other nonvolatile memory. All other nonvolatile memory is considered worn out at first bit failure.
All FLASH use Fowler-Nordheim tunneling for write and erase.
RichardO
Joined May 4, 2013
2,270
It does not answer your question but page 41 of the data sheet addresses how the device fails.
I agree that the data sheet is odd in that it does not give any numbers for life/failure rate.
dl324
Joined Mar 30, 2015
18,326
Spare cells are designed into NAND FLASH so time to single bit failure isn't meaningful. What could happen with NAND FLASH is that capacity will decrease. I don't know how it handles situations where significant storage capacity has failed.
I recently had the bad experience of buying some counterfeit microSD cards from AliExpress. They take lower density parts and hack them to make them appear much larger. The host system sees the fake capacity and the controller starts overwriting data when real capacity is filled. I'd hope that legitimate devices handled cases where available capacity has been reduced significantly (by protecting the existing data).
dl324
Joined Mar 30, 2015
18,326
The process guys tell us what they want and we tell them what works in a practical manner with what we have.
Multilevel cell FLASH are pretty interesting too. Micron is up to 3 bits per cell. That takes some pretty accurate charge control. Not like the old days when you just deposited a lot of charge on the floating gate.
