Working of Single Ended to Differential Op Amp
Qammar
Joined Feb 15, 2018
7
I am trying to understand the working of single ended to differential converter circuits using op amps. I am a bit familiar with op amp having one output but in this case, an op amp with two outputs has been used which is creating difficulty in comprehending its working. Any help regarding the circuit working/interpretation will be appreciated. Please find the attached circuit image as well.
Qammar
Joined Feb 15, 2018
7
Thank you @ericgibbs for your quick response. However, i have gone through this document before creating this thread as i was unable to extract relevant information from the document.
ericgibbs
Joined Jan 29, 2010
21,622
hi Q,
In order to understand your problem, could you give an example of a feature you do not understand, perhaps it will help us in answering your query.
E
Qammar
Joined Feb 15, 2018
7
Actually i am unable to understand how the input has been divided b/w 2 outputs. I can understand op amp circuits with a single output but how is the second output being produced by this circuit?
