Working of Insulation monitoring device
Ian0
Joined Aug 7, 2020
13,310
Insulation is "monitored" by connecting a resistor across it and seeing if any current flows.
The battery is wired as an IT earthing system. (That's nothing to do with Information Technology: wrong acronym)
If the positive terminal is shorted to earth, then connecting a resistor between the negative terminal and earth will result in a current flowing in the resistor; and vice versa.
It seems bizarre that to monitor insulation, first the insulation has to be compromised by connecting a resistor across it.
