work out poly
chandimajaya85
Joined Sep 27, 2023
41
Need a help to work out the formula. I cant get my head around with this to work out. its polynomial with numerator and denominator. what is the formula for this. Thank you
work out Poly:
FLOAT_TYPE num_coeff[] = {-2.42580348918581e2l, 4.43575581447635e2l, -8.6570608699616e2l, 7.34933695653457e2l, -7.02396810482965e1l};
FLOAT_TYPE den_coeff[] = {1.e0l, -8.87493143817912e-1l, 2.75291524634514e0l, -3.88521936154463e-1l, 9.08722079164108e-3l};
FLOAT_TYPE num_poly = num_coeff[sizeof(num_coeff) / sizeof(num_coeff[0]) - 1];
FLOAT_TYPE den_poly = den_coeff[sizeof(den_coeff) / sizeof(den_coeff[0]) - 1];
for (int i = (sizeof(num_coeff) / sizeof(num_coeff[0]) - 2); i >= 0; --i)
   num_poly = num_poly * r + num_coeff[i];
for (int i = (sizeof(den_coeff) / sizeof(den_coeff[0]) - 2); i >= 0; --i)
  den_poly = den_poly * r + den_coeff[i]; } return (num_poly / den_poly);
WBahn
Joined Mar 31, 2012
33,239
You need to provide a lot more detail about what the information you have represents. For instance, just indicating that they are the coefficients of the numerator isn't enough, since the constant coefficient could be the first item or the last item in the array.
Where are these coefficient values coming from? Do you really know them to 15 sig figs?
Work out a toy problem by hand and make sure that your approach is correct before you start throwing code at it.
chandimajaya85
Joined Sep 27, 2023
41
Thank you for the reply. I worked out the formula, is it like this.
num_poly(x) = -2.42580348918581e2 + 4.43575581447635e2 * x - 8.6570608699616e2l * x^2 + 7.34933695653457e2 * x^3 - 7.02396810482965e1 * x^4
And den_poly(x) = 1.e0 - 8.87493143817912e-1 * x + 2.75291524634514e0 * x^2 - 3.88521936154463e-1 * x^3 + 9.08722079164108e-3l * x^4
chandimajaya85
Joined Sep 27, 2023
41
Welcome to AAC.
Is this related to school work?
Ya’akov
Joined Jan 27, 2019
10,307
