Would this be poss, I would like to build, with the help of you guys a self powered load tester for testing long run underground wiring, I have access to both ends of the wire and also have a 12 volt power supply, the power supply is capable of producing 80 ish amps, Ive been testing the wiring with a vehicle headlamp bulb that draws about 4 amps and DMM.
What I would like if poss is a small'ish project box with a volt and amp meter built, something like
https://www.ebay.co.uk/itm/Digital-...hash=item2398b29147:m:m_oggB8PrmZeLzRSclZd-Wg
in and a pot so I can crank up the the amps, I I'd like aprox 0 to 4 amps
if it is poss, where would I start
Thanks
Thanks
