wiring small vintage sew machine motor
MaxHeadRoom
Joined Jul 18, 2013
30,808
If the squares in series with 5 are the fields then it appears to run it full power if AC is applied to 4 and 5.
As a normal Universal motor.
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,808
If you just want to run it full power, identify the two lines that go direct through the fields in series with the armature and apply power to each.
Ignore or disconnect the variable speed unit.
Max.
Jpols
Joined Apr 16, 2018
31
Okay, success! Using the Blue & Grey wires (nos. 4&6) I got the motor to work!! Without the foot rheostat in line, it spins ridiculously fast. Thanks guys! My problem now is that the motor runs clockwise, and I need it to run counter-clockwise. Can you advise me on how to reverse the direction?
Jpols
Joined Apr 16, 2018
31
You need to change the polarity of the field windings WRT the armature.
Max.
Thanks Max:) figured had to change polarity somehow, but as indicated I know enough about electricity to be dangerous :) so you need to literally draw me a picture how to do this with AC:))
Jpols
Joined Apr 16, 2018
31
The motor normally would have run cow, not sure what happened. What is WRT? Did the suppressor or capacitor that was across the brushes have anything to do with direction? The motor runs without the suppressor in place but clockwise. The only thing I did different was remove that suppressor.
28,251
It would probably be simpler to swap the connections to the two brushes. Field winding connections are often quite fragile, and breaking one could end the game, as it were.
MaxHeadRoom
Joined Jul 18, 2013
30,808
WRT, 'With Respect to'.
The suppression cap does not have any influence on the ability to run.
This is the typical Universal motor so it may be easier just to swap the brush leads as suggested.
Max.
Jpols
Joined Apr 16, 2018
31
Max.
Thanks Max. This morning I switched wires to the brushes. Still runs clockwise! When it came out of the machine, it was running CCW, (it has to for the machine to operate properly). Also discovered that the motor runs using the black (#6) and blue (#4) wires. It actually seems to run smoother for some reason. Anyways, not sure what to try next. So close, yet so far:)
Jpols
Joined Apr 16, 2018
31
Max.
Max.
How do I go about changing the polarity of the field windings? Am assuming the brush contacts would remain the same then? The grey wire enters one of the fields, and the black & blue both enter the other field.
MaxHeadRoom
Joined Jul 18, 2013
30,808
As they are in series I am not sure why it did not work with the armature?
But the easiest way is when the two field are connected one after the other, not as the pic I showed where they where either side of the brushes.
When they are separate you need to swap or reverse the connections each in turn.
It should be fairly easy to trace which applies in your case.
Incidentally it is advisable to run it with some kind of load as these motors operate in a runaway condition and can easily reach 20krpm or higher.
Max.
Jpols
Joined Apr 16, 2018
31
It's not clear to me what connections I swap or at what location I do it in the motor. Is it possible to give me an example? ie. Take the blue wire at location X,cut it, take the purple wire at location y, cut it. Take wire from x and connect to y, then take wire that was at y and connect to x . Sorry to be so dense, but I am learning a lot and do appreciate the guidance:))
MaxHeadRoom
Joined Jul 18, 2013
30,808
If you can draw out Exactly what you have and the disposition of the fields with respect to the armature, i.e. if the fields are connected to each other rather than each side of the armature as in post #30.
You should end up with either field-armature-field or field-field-armature.
I still don't understand why it did not reverse when you swapped the brush leads?
Max.
Jpols
Joined Apr 16, 2018
31
Max.
I too am baffled why the brush connection swap didn't work?? I will take the motor apart again so I have a better look at the windings.
Jpols
Joined Apr 16, 2018
31
Okay the attached sketch is what I believe I am looking at. Fields are joined together at one end, Grey to one field, then a field wire comes out same end to brush. Other field, black & Blue enter, then at opposite end of field, a wire comes out to the other brush.IMG_3930.jpg
Jpols
Joined Apr 16, 2018
31
The mystery is, Why was it running CCW properly when connected to circuit board and not now? Would the Red wire (that looked like a ground to the motor frame but was connected to the circuit board at pin 2) have a role to play?
MaxHeadRoom
Joined Jul 18, 2013
30,808
The frame ground should Not in any normal circumstances have any thing to do with the running operation.
That appears to be a very strange non-standard motor connection.
Max.
Jpols
Joined Apr 16, 2018
31
Max.
Did you see my sketch of the connections to the windings and brushes?
While exploring online I came across this note to somebody trying the same thing. Can you make any sense of it? :
"The brushes in a universal motor are tied to the same lines as the stators, so the rotor switches polarity the same as the stator poles. To reverse it you must 'CUT' the two lines to the stator/rotor and put a double pole double throw switch in.
You want to cross the connections to the rotor brushes, but not the lines to the stator. Hook the cut lines from the stator to the two end poles of the switch and put the rotor/brush wires the center poles of the switch. attach two jumpers to the other end of the switch and 'cross' them and attach to the first end."
