Is this possible? I want to put 3 24V alternators on my car to charge a 84V battery pack. 3 24V alternators should put out about 86.4V (14.4x6), but I am wondering if the alternators will all keep the same voltage (24V) between them. I would think so if the since wire is hooked to the negative of the alternator... But I guess the hard part is isolating the body of the case from the body of the car. I believe the case is ground, please let me know if you know.
But that is the thought, is it possible?
And if that is not possible, is it possible to make 84V alternators? Then I could hook 3 up in parrellel to get 100amp output. Alternators are usually limited to about 2,000-3,000 watts. I am looking for about 100 amps total at 84ish volts. So 8400 watts.
Eric
Eric
