I'm currently working on the design of a wireless charging circuit to produce an output of 5V & 1A.
The transmitter circuit is supplied with 15V and generates a pulse via the use of a 555 timer (NE555P). The timer is configured to produce an output frequency of ~10kHz-13kHz.
However, the maximum current output of this timer is ~200mA (too small to feed in to a receiver coil).
To amplify this current, I have used an NPN BJT (2N2222) to drive an n-channel MOSFET (IRF540). The drain of said MOSFET is connected to an inductive load made of rounded copper wire (L ~ 0.93mH), acting as a transmitter.
The receiver coil is made identical with a 1:1 turns ratio, connected to a capacitor in parallel with a diode bridge (1N4007) to fully rectify the pulsating DC waveform received from the transmitter coil. This is then fed through to a capacitor and LM7805 5V regulator. At the moment I am connecting a load resistor (1K) in series with an LED to ensure the circuit is working (and it does).
A circuit diagram is attached (image file)
My first problem:
The IRF540 I am using has a large heat-sink connected, as it becomes quite hot very quickly. I am not sure why this is. The current measured across the output of the transmitter coil is close to 2A and 15V (I will recheck these values to confirm).
In addition, it is worth noting that this circuit does allow energy to be transferred from one circuit to another (this has shown through testing). However, I am not satisfied with the fact that the MOSFET becomes so hot so quickly. Is there a problem with its ON/OFF state? A problem with the input resistance? (I am a final year EEE student, so please forgive any lack of understanding with regards to the operation of the MOSFET in this particular instance)
My 2nd problem
The voltage regulator connected at the output produces 5V and ~4-5mA (as expected considering 1k resistor value added with LED at load, although this is not shown correctly in the circuit diagram below). I have ordered a 10ohm and 5 ohm power resistor (50W rating) to produce 0.5A and 1A, respectively (to provide 2.5W or 5W for charging). Other resistors used to control the load current with smaller power ratings become very hot very quickly (a 3.3ohm resistor I used started to become very hot, even with a 14W power rating with a 5V regulated output).
Now, if I am able to control the current using a more powerful, suitable resistor to produce the desired output current, how would I then connected this to a USB port to provide a charging mechanism? Does anybody have any experience in setting one up or trying one out? Thank you in advance to anybody who can help me. I'm not entirely sure how to incorporate this in to my current design.
Finally, please let me know if I can be any more specific in key areas ( am happy to provide any further information, if required). I am somewhat happy with the fact that my design mostly works, although if this was not a FYP then I'm sure this circuit would not be considered very good, considering it appears that it will be unable to charge anything for more than 30 seconds or so (due to overheating of components).
Circuit diagram included below
My first problem:
My 2nd problem
