With what formulas can I choose the diameter of the wire for the high frequency transformer?
I don't know if there is a precise formula for an optimum wire size, but you need to start with the number of turns required and the space available. This will put an upper limit on the wire diameter. Then you need to consider your skill in winding to use a wire size close to the limit. Then you need to consider the current in the winding and the temperature rise. Skin effect may also dictate a smaller wire size and so it goes.With what formulas can I choose the diameter of the wire for the high frequency transformer?
Actually, according to the TS’ other thread, try GHz.The really big question would be what you mean by "high frequency", kilo-hertz or megahertz, or maybe just 400 Hz?
Hi there,With what formulas can I choose the diameter of the wire for the high frequency transformer?
| Thread starter | Similar threads | Forum | Replies | Date |
| A | Shed a light on this wires gatherer in 400/40 Watt rice cooker | Technical Repair | 1 | |
| B | Wire Strippers | General Electronics Chat | 23 | |
How to drive a 5 wires stepper motor without Arduino ? | Digital Design | 17 | |
| A | USA 240V three wire L1, L2 and a Ground | Power Electronics | 22 | |
wire wrap pins | Marketplace | 10 |
