As title,
Can I wire 1 24 AWG, 1 22AWG and 1 20 AWG wires into a 18-22 AWG ring lug ( PV18-8R-CY )?
Thanks
Thanks
That happens a lot with new helpmechanical strain from crimping which maybe break wires or simply shear them off.
CERTAINLY THAT IS TRUE!!! and, consider that I was not suggesting any crimp at all, but only a solder connection, certainly any crimp would be the wrong one. The serious benefit of not crimping is allowing repair ability. Not such a big deal with ring terminals, but a huge deal with connector pins.You can do it (we've all do it before) but it's not recommended as you lose the proper crimp specifications for mechanical holding, resistance/current capacity that are usually designed for single wire crimping.
You lose the reliability of a proper crimp.
Properly made crimps do not require solder. If you need to add solder, it's not a proper crimp.
| A | Shed a light on this wires gatherer in 400/40 Watt rice cooker | Technical Repair | 1 | |
| B | Wire Strippers | General Electronics Chat | 23 | |
How to drive a 5 wires stepper motor without Arduino ? | Digital Design | 14 | |
| A | USA 240V three wire L1, L2 and a Ground | Power Electronics | 13 | |
wire wrap pins | Marketplace | 10 |
