Wine cooler
Nvmarv
Joined Aug 27, 2025
21
I have a wine cooler that quit working..I have power on high voltage side after replacing the 2 transister and a capacitor both with the yellow arrows but still have no power on low side anywhere..I tested the transformers and both tested good and no shorts there but curious about why the voltage is only .5 on a 200 volt scale..nothing on low side has voltage…somewhat a newbi….tks in advance
wayneh
Joined Sep 9, 2010
18,130
If you can, test for ESR. That's how they fail. The capacitance may not be out of spec but the resistance climbs.
But once you've taken the time to remove the cap, just replace it no matter the test. They age and have a limited lifetime. Putting a used cap back on the board makes no sense.
Nvmarv
Joined Aug 27, 2025
21
They tested bad..the cap had a bulge too..the transistor on left goes to ground on left or bottom side
Nvmarv
Joined Aug 27, 2025
21
A somewhat newbie question.. does low side need a load on it to have voltage on output side of transformers
Nvmarv
Joined Aug 27, 2025
21
Ok I did some further testing and even did a voltage injection on output side of both transformer’s using a 12 volt bat and I have voltage to all output ports.. the transformers all show low resistance between each leg.. im assuming that is maybe bad now.. shows zero ohms on all.. is it possible that both transformers went out at same time?.. what further test can I do on them to make sure.. the 120 v injection spots I used are the yellow arrows
panic mode
Joined Oct 10, 2011
5,133
so problem must be on the HV side... check diode and if you get DC across large caps. and before you power it up again, please cleanup the board. spray it with alcohol and use brush. HV section needs clearance between adjacent tracks and the crud may be causing shorts or leakage currents.
Pyrex
Joined Feb 16, 2022
523
As you were advised, check the voltage on the two large black capacitors. If the mains voltage is 230V, there should be about 150V on them.
Thie SMPS must provide output voltage even if it is not loaded.
Pyrex
Joined Feb 16, 2022
523
Check the voltage with a multimeter in DCV mode on one and the other capacitor.
Transformer resistance 0.1 or 1 ohm - is normal
Nvmarv
Joined Aug 27, 2025
21
I cleaned up but no change..diodes test ok but have to take out to get an accurate reading..where is smps?..the surface mounted power supply?
