I was trying to use a impeller connected to a 3 V DC motor to light a LED (red). The output voltage from the DC motor (due to wind) is intermittent and varies between 0,2 V to 1 V. The LED does not light up as it need minimum 1,5-1,8 V. Is there someway i can use 100 microfarad capacitors, NPN transistors and simple diodes to make a circuit where the voltage from the motor slowly charges up the capacitors and when the capacitors have sufficient voltage, they automatically discharge across the LED to light it up?
Regards,
Singh
Regards,
Singh
