"What are the type of window detectors?" Someone can help me ? I can't fint it.
Thread Starter apollo321j Joined Dec 30, 2020 28 May 25, 2021 #1 "What are the type of window detectors?" Someone can help me ? I can't fint it.
ericgibbs Joined Jan 29, 2010 21,622 May 25, 2021 #2 hi again 321. By window detectors do you mean a method of sensing if two parameters fall within a specified band.? ie; voltage window range.? E
crutschow Joined Mar 14, 2008 38,911 May 25, 2021 #3 apollo321j said: What are the type of window detectors Click to expand... Window for what?
Thread Starter apollo321j Joined Dec 30, 2020 28 May 25, 2021 #4 Hi eric Yes in attached pdf file I did all question but one question remain third one ,and Window comparator compare ipnut voltage with upper and lower threshold voltage and if it's in interval of them Vout=VSATURATİON. Attachments ECC_Experiment_3.pdf 436.5 KB Views: 10
bertus Joined Apr 5, 2008 23,023 May 26, 2021 #5 Hello, Read the attached PDF. Bertus Attachments tidub01 Window Comparator Reference Design.pdf 1.5 MB Views: 7
ericgibbs Joined Jan 29, 2010 21,622 May 26, 2021 #6 hi 321, Read thru this PDF, ask if you have a query. E Update: I posted this yesterday, just noticed it had not been posted !.! Attachments Adding Extra Hysteresis to Comparators.pdf 178.6 KB Views: 5
