Window detector with latch output
bosko47
Joined Mar 24, 2016
23
I'm trying to design a window detector with a latch output. The window range is 2.5 to 3.5 volts, outside this range I want the LED to light up and stay lid until reset. Am I using the latch setup correctly? I tried a simulation in Multisim but it didn't work correctly, not sure if it's a circuit error or simulation error.
AlbertHall
Joined Jun 4, 2014
12,629
Your reset circuit is upside down. Connect the resistor to +5V and the switch to ground.
This circuit will only work correctly if you use open collector output comparators.
bosko47
Joined Mar 24, 2016
23
I'm using LM339 comparators, which have open collector outputs, so all good there. I changed the reset circuit around. Now the LED lights up when the input is outside the window range, but it doesn't stay on when the input goes back inside the range...
38,538
It's a circuit error.
You need to use NAND gates for the latch instead of NOR gates to get the logic right.
(A NAND gate latch is triggered when the input goes low and a NOR gate latch is triggered when the input goes high).
LTspice simulation shown:
bosko47
Joined Mar 24, 2016
23
Thanks that will work, but the only problem is I can only use a single 74LS02 quad NOR chip. Sorry I should have mentioned this.
AlbertHall
Joined Jun 4, 2014
12,629
If you simulate this circuit with the extra NOR as an inverter you will discover that there is a problem with the LED but it is easily fixed.
