Me and a few teammates need to build a wind turbine for a certain course this semester and i have quite a lot of questions, so i'm hoping somebody here can help me or point me in the right direction. We are already given some components:
I was planning on using a buck converter and a boost converter to convert the DC voltage from the AC-DC converter to the needed DC voltage to charge the battery.
To charge a lead acid battery, do i just need to apply around 14V DC to the battery?
Since the generator output will vary depending on wind speed how do i send the current through the right circuit (buck or boost converter)?
For the switches in the buck/boost converter i would probably use mosfets, but how to i control these so that the converter outputs the needed voltage to charge the battery?
For the AC-DC converter, i was thinking to directly connect the battery to Vdd, using source and drain for AC-DC conversion, adding a 10nF capacitance to the COMP pin (recommended in datasheet p30) and not connecting the others pins. Would this create any problems?
Thanks in advance for any help.
- brushless motor: Turnigy Aerodrive SK3 - 6374-149kv (https://hobbyking.com/en_us/turnigy...rushless-outrunner-motor.html/?___store=en_us)
- ARM: Cypress CY8CKIT-049-41xx PSOC 4
- AC to DC converter: STMicroelectronics VIPER53SP-E (http://www.st.com/content/ccc/resou...df/jcr:content/translations/en.CD00144872.pdf)
