Will this hand made transformer work?
Ghostek
Joined Apr 2, 2024
1712084620648.jpgi made a hand made transformer and wanted to ask the forum how and with what should I power it. And will it even work.
dl324
Joined Mar 30, 2015
18,454
Welcome to AAC!
You have a high turns ratio. What voltage is the insulation rated for? Is the "core" made out of ferrous material?
Do you have a step down transformer you can use to test it?
Ian0
Joined Aug 7, 2020
13,252
I'm assuming that you made the core out of iron, and wound it with insulated (enamelled) wire.
In which case, yes, it will work.
It won't be great, but it will work.
As you have only one lamination, its cross sectional area will be very small, so it will need very little VT constant to saturate it. (VT is voltage * time) So it will have to work at a low voltage and high frequency.
As your core is silicon-iron, it won't work very well at high frequency.
Your primary and secondary are on different parts of the structure, so the coupling between them won't be very good.
If you use a stack of laminations, arranged in a rectangle, then wind the two windings all on one side, one winding on top of the other, then it might be quite good.
Alec_t
Joined Sep 17, 2013
15,156
If the enamelled wire is in direct contact with the metal laminations there is a risk that any movement will damage the enamel insulation and result in a short circuit.
28,160
OK, "will it work?" "Yes BUT" is the answer. The side with very little wire will deliver a very low voltage if it is used as the output (secondary winding)
As has been stated, it will not be very efficient, and that means it will possibly get rather hot.
What were you planning on using to supply the power to the transformer??
