Wifi router does not turn on
Bassquake
Joined Feb 16, 2018
97
Does it not have the option to use a 10A scale? I'm not surprised that the router draws more than 200mA.
Another approach is to measure the voltage across a low ohms resistor while under load. For instance, finding 0.9V across a 1Ω resistor (in series with the power to the router) would tell you it's drawing 900mA.
I bought a new multimeter that has 10A option. Testing the router shows it flashing periodically 0 to -0.654 and other random negative numbers.
Dodgydave
Joined Jun 22, 2012
11,395
That sounds like it's taking too much current from the psu, probably because its got a short on the supply line, or the psu isn't upto scratch, did you remove the diode in post#15??
wayneh
Joined Sep 9, 2010
18,154
I'd also continue testing the power supply. Got any 12V lightbulbs? Ideally you'd have one that draws at least half the rated current of the PSU. For instance 1A at 12V is 12W, and so a 10W bulb would show directly whether the PSU is up to the job. If the bulb lights, you've eliminated the PSU as the culprit.
Bassquake
Joined Feb 16, 2018
97
I haven't yet. Id need to remove the switch to be able to get to it. I will get around to it at some point.
Bassquake
Joined Feb 16, 2018
97
I've tried about three different 12v 1A PSUs and they all work fine in other devices.
djsfantasi
Joined Apr 11, 2010
9,237
A 12V 1A supply should always work if it’s laid needs 1A or less (usually less!). But connect sometime that needs 2A, 3A and it won’t work. Anything more than the 1A it is rated for.
The other devices in which the PS worked required less than 1A. That’s why we need to locate he short or measure the current o
Bassquake
Joined Feb 16, 2018
97
Iv'e tested the psu's with a 12v fan controller and a cob led. Lights up fine. Using multimeter to test current, it reaches the 0.6A the led requires.
wayneh
Joined Sep 9, 2010
18,154
Okay, that considerably reduces the odds of the PSU being the problem. It should be able to produce the rated current at the rated voltage, though, and until I've seen that proof, there is still a chance the PSU is a problem. Like I said, the odds have now come WAY down, but they aren't yet zero.
I'm being a stickler on this issue because in my experience, most devices fail because of a failed PSU. I never even begin to look elsewhere until I rule that out completely.
