wierd fan problem
BlakesterGamer
Joined Apr 20, 2016
92
ok i picked up a free dell dimension 8400 with a pentium 4 and 500 mb of ram and 160gb Hard drive so i turn it on and only sometimes it boots into windows xp home edition but almost every single time i try the fan starts spinning really fast and it gets super loud it gets almost as loud as my lawn mower some plzz help me!!!
18,162
I predict a more serious problem, but we'll see.
How far along the boot progress does it get? Have you read your Event log?
18,162
no the screen just goes black
Do you know how to boot into BIOS (to avoid using the hard drive)? Or try booting from a CD or an external drive.
The screen going black could be many things. When in the boot process does this happen, early or late? For instance a very earlier failure could be bad RAM whereas a late failure leans towards the video card.
And keep in mind that, even if you succeed and get it working, it has virtually no value. Your local electronics recycling center may have ten machines similar to your's all in a pile. Know when to hold 'em, know when to fold 'em.
MrSoftware
Joined Oct 29, 2013
2,273
The fan is probably fine. Depending on the model, many of them have thermostatically controlled variable speed fans, and when you first turn them on some of them will go full speed for a brief couple of seconds. If there's something wrong that's causing the boot process to hang, then the fan might get stuck at full speed. OR something is going wrong causing the CPU to get really hot, which in turn would cause the fan to go full speed. In any event, I suspect the fan going full speed is a symptom, not a problem. Clean all the dust off and then see if you can sort out the boot problems.
BR-549
Joined Sep 22, 2013
4,928
After neutralizing your body, pull all boards and re-seat. Memory, video....etc.
Then listen for post code.........beeps.
bertus
Joined Apr 5, 2008
23,005
With old systems, it can well be that dust has been collected in the heatsink.
Hold the fan and blowout the heatsink.
Also the fanspeed can be controlled by the motherboard.
BlakesterGamer
Joined Apr 20, 2016
92
ok i put a new hard drive in i had laying around in storage and that fixed the fan prob but i still get no signal on the monitor so i replaced the ram but still no signal and then i got a old geforce4 card 64 MB out of a friends broken pc in my basement for repair i put it in the dell dimension and
i turned it on the graphics card fan did not even spin up so i think i need to dig around in a bunch of old computers for a working graphics card
MrSoftware
Joined Oct 29, 2013
2,273
Graphics card fans are typically not the highest quality fans, it's possible that the fan on your buddies card is just dead. Unless it was working while still in his pc..
If the settings in BIOS are not important to you, then it might help to restore the BIOS settings to the factory defaults so that you're starting from a known state. Sometimes you can select this option in the BIOS menu, sometimes there's a jumper on the motherboard to reset it.
BlakesterGamer
Joined Apr 20, 2016
92
already tried that but thanks for the suggestion later today i am brining the pc to my local computer store
ian field
Joined Oct 27, 2012
6,536
How many pins on the fan connector?
It could be sensing excessive temperature and running the fan flat out.
