Why2 UART Ports on a device
eswarkumarvarma
Joined Jan 25, 2019
9
Hii ,
While dealing with a router hardware I found there are two uart ports , i found one uart port is used for debugging, what is the use of the other uart port . why devices will be having two uart ports
jayanthd
Joined Jul 4, 2015
945
Hii ,
Maybe the other uart port is for communication or configuration.
One is for debugging the device.
35,320
Maybe, maybe not.
Here are some possible usage for multiple UARTs.
1) Communicate with other external devices and controllers on a bus or network, RS-485, CAN, irDA, WiFi, Bluetooth, NFC, USB, X10, modem.
2) Communicate with local devices on the PCB, e.g. temperature sensor, accelerometer, GPS, RTC.
3) Communicate with external devices and peripherals, scanner, printer, camera, keyboard, mouse.
4) Communicate with other MCU.
5) Communicate with a host PC.
