To ensure the transistor turns off, prevents false triggering pulses.
Circuit 1 is used to ensure the FET is turned off if there is no input signal, like from a microcontroller port that has nor been initialized.
And it is fairly normal to include a small series resistor too.
The resistor in circuit 2 is only there to keep the gate from "ringing", Google gate resistor for more information. The resistor to ground is the only way to completely assure the gate won't turn on until a higher voltage is present, not just a "spurious" voltage, that can partially turn the mosfet on.so in the Circuit 2 , the resistor would not be put off even if we have a resistors on series ? bcz from my understanding , both they will consume current the same why , my problem is that i dont see the difference between the two circuits, and why it is better to use the resistor connected to ground
Thanks alot
+1 for me.Small point!. I would not use term "ground" is this sense.I would prefer to call it "common". But thats just me.
