hello guys
i have already finished a project that detects and amplifies heart sounds successfully!
i wanted to try different circuit and test it but i found something weird on it,
i can test the output signal from the microphone clearly but once i feed the signal into an amplifier i got nothing in the output!! two batteries as voltage supply to amplify the bipolar signal but i get no signal at the output!!
i used different types of op-amplifier tl074, OPA2134 and also lm324 just to check the signal and get the same results!! i just connected the first stage of the preamplifier and also got no results!
is there anything wrong in the schematic??
