Why the ratio of Ic/Ib on BJT is not constant?
jacob_c
Joined Oct 13, 2020
13
Hi. The schematic of amplifier using BJT and the result is attached.
What I learned is that the beta, ratio of Ic/Ib, would be constant.
However, the ratio of Ic/Ib varies by the time.
I googled for this and found out that the beta varies with temperature and Ic but does it vary that much?
Ic is in range of 1.1mA~1.55mA from the simulation. How can I explain this situation?
WBahn
Joined Mar 31, 2012
33,368
Read the text regarding transistor characteristics and then take your best shot at giving an explanation. That will give us a starting point. We won't answer your homework questions for you.
Here's something to get you thinking -- let's say that we have a transistor set up so that Ib = 0.1 mA and Ic = 10 mA when Vce is 10 V. If we then keep Ib the same and decrease Vce, do you really expect Ic to remain 10 mA? Even when Vce is reduced all the way to 0 V? When it's made negative? If not, do you expect the ratio of Ic/Ib to change smoothly, or all at once at some point?
jacob_c
Joined Oct 13, 2020
13
Thank you for answer. But can you give me some more guideline for it? I'm trying but it's not quite easy to get.
LvW
Joined Jun 13, 2013
2,070
I must admit that I do not understand your problem description.
* You simply claim that this ratio would vary by time. No explanation or verification.
* You simply claim that the Ic would vary between 1.1 and 1.55 mA "from the simulation"....What did you simuiate and which parameer did you vary?
* What is the meaning of the shown sinus signal? What does it show in the context of your question?
* How did you arrive at the shown parts values? (They look rather strange).
jacob_c
Joined Oct 13, 2020
13
The simulation is conducted base on the schematic attached. I gave VSIN input of 10mV amplitude between 0 to 1ms to check
the beta, which is equal to collector current/base current.
With the given DC bias and VSIN input, the Ic varies btw 1.1~1.55mA.
The sinus signal shows beta(Ic/Ib). I expected this to be constant but it shows sinus signal as you can see.
The parts values are given.
Sorry for poor explanation of my question
LvW
Joined Jun 13, 2013
2,070
OK - I did not recognize the bottom of the sinus plot. Now I see - the ratio Ic/Ib.
However, something must be wrong with your circuit.
With only 2 volts supply, I assume Vce=1V. Hence, the base cutrrent is app. Ib=(1-0.7)V/1k=0.3mA.
For a current gain of only 100 we would have a collector current of 30mA. And the voltage drop at the collector resistor is 30V.
Do you now understand my remark about the circuit and the parts values?
I suppose, you did not check the DC operating point prior to the TRAN simulation?
38,952
Wherever you learned that is giving you false information.
A real BJT transistor (or the model used in a Spice simulator) has a beta that varies with collector current and temperature.
In the real world, there is also a significant manufacturing variation between transistors, even of the same part number.
Just look at a typical transistor data sheet to see this.
That is why a circuit is normally designed so that its DC bias and AC gain is relatively insensitive to the actual transistor beta value.
LvW
Joined Jun 13, 2013
2,070
Yes - of course, thats true.
However, the questioner has observed a change of app. 40% .
This huge deviation was caused by the fact that the transistor was not operated in the linear region (where the current gain beta is specified).
In contrary, the pn junction between C and B was open and he has measured - more or less - the properties of an open pn-diode.
jacob_c
Joined Oct 13, 2020
13
yep according to the same simulation above, the Vce is about 750mV and Vbe is about 650mV. Due to the input swing, there are some intervals that Vbe>Vce.
But usually it is on forward region while the large swing of beta is all around.
Since all values of parts are given, I cannot change it.
38,952
At that low Vce, the apparent beta will vary significantly with current since you are near the saturation point of the transistor.
Beta is normally specified at a few volts of collector-emitter voltage.
If you cannot change the circuit, then it is what it is.
Audioguru again
Joined Oct 21, 2019
6,826
Beta is current gain. But most transistor circuits are made to produce voltage gain.
Beta is used to DC bias a transistor to avoid clipping distortion.
But the supply voltage of only 2V is much lower than the 10V where the beta is listed on the datasheet.
The transistor is biased do that the collector voltage is swinging above and below the base voltage in this simple circuit and its voltage gain is only 10.75 times.
