Why not use 5A, 100kHz switching regulator output directly for induction heating?
Luna Tuna
Joined Jan 17, 2019
17
I'm in the process of designing a circuit for a personal project's induction heater.
I want to use LT1074 for which there is a spice model included in Lt Spice install.
https://www.analog.com/en/products/lt1074.html
So, these inductor circuits you find by googling seem to have a Royer Oscillator with two transistors. Why not, since the frequency is already high enough, use the 5A max output of the LT1074?
BR-549
Joined Sep 22, 2013
4,931
The "supply" does not determine the current.....the supply only limits the current.
The "load" determines the amount of current.
BR-549
Joined Sep 22, 2013
4,931
Tell and show us what you have, what you want and how you want to do it. You gave a link to a switching regulator. Where are the two transistors? Where is your circuit? What is your power source? What is the load? What are you trying to save?
