Why my operational amplifier TL3472IDR doesn't work properly with 1Mhz ?
Samaze123
Joined Sep 30, 2023
4
On a breadboard i'm using an Arduino Nano to produce a square signal of 1Mhz.
I pass it through a volage divider to keep 1V.
Until here all is working properly.
Then i use my op amp TL3472IDR to make a volage follower. The op amp can't produce a correct signal and using a scope i'm seeing that my square signal is almost flat.
This op amp is, according to its datasheet, functional up to 4Mhz and its slew rate is 13V/µs. ( I put the datasheet in the attachments)
In the image, the blue is the arduino output and the yellow is the op amp output.
Thanks in advance for your answers.
ronsimpson
Joined Oct 7, 2019
4,823
Assuming D3 is the output, there is a cap to ground that shorts out high frequencies. Why?
Your amplifier is built to have an input of 0 to 2.8V assuming a 0 to 5V supply. Don't get outside this range.
It appears you wany a 0 to 3V signal out. Most op-amps are not happy with the output voltage close to the supply voltage. The output voltage should be 0.3V above the negative supply and 1.3V below the plus supply.
If you violate any of these voltage limits the amp will get slow.
ericgibbs
Joined Jan 29, 2010
21,576
hi Sam
A 1n0 at 1MHZ has an impedance of 159R
The Nano output is 5V, so that's 5v/159R = 31mA, IIRC the Nano is rated at 20mA max.?
E
On checking, it is claimed to be able of higher output current.
Samaze123
Joined Sep 30, 2023
4
i put the cap to avoid this :
Thanks for your answer
ericgibbs
Joined Jan 29, 2010
21,576
Hi Alex, @Bordodynov
Your simulation post #9., is using a 50kHz pulse frequency, the TS is using a 1MHz pulse frequency.
Also, an output pulse height of 2.5V, with a MCU Vsupply of 5V, will be 'marginal' for a Logic '1'
E
Description: Nano
As the input voltage increases from 0V, the input is read as 0 and switches to 1 at 2.60V.
As the input voltage decreases from 5V, the input is read as 1 and switches to 0 at 2.35V.
Hysteresis is 0.25V.
Samaze123
Joined Sep 30, 2023
4
hi sam,
This sim is using the TL3472 model and the 1MHz square wave source.
The circuit and OPA give a very poor performance at 1MHz.
E
Okay thanks, do you know another OPA that could works with this circuit ?
And what if I add 1V at the end of the voltage divider ? The signal will be in the opa working range ?
Bordodynov
Joined May 20, 2015
3,431
ericgibbs,
I first made sure that the proposed circuit does not work at 1 MHz. I was lowering the frequency until it was functioning normally. Also I showed the levels of zero and one. This I did to show the unsuitability of the operational amplifier.
Here's a more suitable operational amplifier:MCP631.png
ericgibbs
Joined Jan 29, 2010
21,576
Hi Alex,
The latest circuit shows a Vout that is below the required logic level for the Nano MCU.
What do you think about posts #14 & #15?
Eric
Description: Nano
