- Joined Jan 23, 2018
- 28,502
I did not claim that it is impossible, but certainly it is horribly complex and a whole lot of effort.
This is not far different from a lot of the early machines I had. They were very modular and offered upgrades. Despite calling it "DIY" it's really just about a configuration, not about "building" anything.Looks to me like that adheres very much to what I stated, namely that the components fit like a puzzle and you are limited to the options available from that manufacturer for that make and model.
The prices on their pre-built machines aren't cheap, but don't look too outrageous, but I didn't see any of them that will ship before the 4th quarter.
Hi,Why So?
Hi,Mr AL neglected the power supply and battery portion, one of the more expensive segments.
For an education about laptop computers, I really suggest getting one non-repairable dead one and carefully disassembling it, payng attention to how things fit. That will provide a cheap education that will provide some valuable insights.
AND, for an exercise in frustration, try to put it back together. Not making it work, just re-assembling it. That is a pain all in itself.
Certainly theexternal screen option is quite valuable. I was given a very nice laptop with a cracked LCD screen and I am hoping to be able to get a similar model that has died so that I can swap the lid with the screen. Exchanging sections will still be a major effort but not nearly as much as replacing the display. At least that is what I am hoping for.The screen on my laptop died. Maybe it is just the backlight.
I plugged in an external LCD monitor and I'm good to go. Still running some old apps on Win XP.
Hi,That is an interesting question: "One thing you made me think about here.
Can you use the screen from an old laptop for a different computer. That would allow changing the entire guts of the laptop to something more modern."
Every laptop computer that I have touched has the display integrated into the open-able part of the case, and the connection ismost often a flexible printed ribbon cable. Of course all of the displays are some form of dot-matrix, with mostly a similar aspect ratio.
So probably the display data format is similar for the majority of screens. But I doubt very much that the actual circuit details will be available, nor the specific data format information.
So there will be another challenge that I had not considered.
Hi,The screen on my laptop died. Maybe it is just the backlight.
I already did that test. I can see color pixels but no image.Many of the older laptop computer used a florescent tube backlight, and that tube would fail, with the result of no image visible. The simple and easy diagnostic trick is to have the laptop on and powered and then shine a bright flashlight into the screen from very close. If a bit of image can be seen, then it is a failed backlight problem. Either the tube or the inverter driving it. Most often it is the tube.
| Thread starter | Similar threads | Forum | Replies | Date |
| T | estimate how many ampers should provide PSU | General Electronics Chat | 8 | |
| K | Flashy Flashy to get as many leds flashing individually, | General Electronics Chat | 38 |
