Maybe the chip is in backwards, or something is mis-wired?
No, it was working ok but then it failed and started to get hot.Likely a wiring error.
I removed the MOSFET but it was still getting hot.Why not place the LED across the Mosfet load?
Replace with a 10k gate to GND.
Max.
What is the full part number of the IC?
Not sure, I have had these 555's for several years, I am unsure where they came from.Did ebay (or AliExpress or another Chinese online department store) send you a fake 555 IC?
No, I haven't replaced the 555 IC and could be difficult because I didn't use a IC socket. I will make a new circuit board and try again.NE555P is the bipolar version. It can operate on supply voltages from 4.5V to 16V.
Have you tried replacing the IC with another NE555P?
True, as Bertus said, there is no problem with pin 7 not being connected.There is no problem with pin 7 not being connected.
The circuit shown is a hysteretic oscillator:
https://www.allaboutcircuits.com/textbook/experiments/chpt-8/555-hysteretic-oscillator/
Perhaps lowering the value of the 220K will help, as the circuit is VERY slow now.
Bertus
Yes, it did until for some reason it suddenly it started getting warm then hot I don't quite understand why it's getting hotIs the output of the 555 alternating with the 15 seconds interval?
Bertus
Try removing the FET from the circuit and check the 680 ohm resistor.I don't quite understand why it's getting hot
I have done this. When I connect the 12vDC supply the LED lights but after 5-7 seconds the 555 gets very hot.Try removing the FET from the circuit and check the 680 ohm resistor.
SG
I'm seriously not going to bother replacing the 555. I could remove the capacitor and use it again but that's about it. It's only a simple circuit but not sure why it was working but now isn't.My solder sucker can easily "slurp" the solder off a solder joint in one second of time. Then a defective IC is quickly replaced.
Did you measure your 12V? I have a 9V wall wart that produces 18VDC when it has no load so yours might also have a voltage too high for the 555 when it does not have its rated load.
by Duane Benson
by Aaron Carman
by Jake Hertz
by Jake Hertz
