Funny how I referred to spook's gif in the immediately following post.Marcelo Besch said: ↑
@studiot I'm sorry! About what you said: I simply don't understand what difference would exist if the metal body was grounded or not. Look at the GIF sent by @nsaspook: what difference would there be if that faraday cage was grounded?Click to expand...
NSASpook
The difference would be that (most of) the electrostatic field energy would be shunted into ground instead of charging the enclosure and the inside would still be neutral.
Following on from the thought experiment I suggested earlier I also suggested another one.
Spook has shown how opposite sides of a Faraday enclosure can be at different voltages in order to neutralise, within the enclosure, an externally applied field.
So in free air inside the exposure there is no field.
But what about a conductor passing through the middle and connected to the opposite faces at different voltages?
More to the point,
In post I suggested a thought experiment (or even are real one) to examine the situation of two conductors, with and without ground comprising a signal conductor and a shield.
Why are we doing all the work here?
