Conventional superconductivity is a special QM case where the electrons are coupled into a singular state. The electron fluid cannot be resolved into individual electrons. It's not just a perfect conductor.What does superconductivity or resistance have to do with it?
There are still electrons, with an electric field, moving in the superconducting wire, causing the magnetic field.
The electromagnetic force (field) is fundamental, separate electric and/or magnetic fields are the physical/mathematical manifestation we use. Superconductivity and resistance transform the EM force into the fields we use to describe interactions.
It's still the EM force, just expressed as magnetic energy using the electromagnetic force between the charge of electrons.
https://en.wikipedia.org/wiki/Electromagnetic_field#Static_E_and_M_fields_and_static_EM_fields
