Why Fan speed is controlled through discrete step regulators and not some continuous regulator ?
Abhinav Himanshu
Joined Feb 18, 2016
10
I have always wondered why are we limited to change fan speed only in discrete steps and why not continuously from zero to max value. As it is very annoying when one want a speed in middle of those two discrete steps. Thanks in anticipation! :)
LesJones
Joined Jan 8, 2017
4,543
I suspect that the speed is controllred on your fan by switching between taps on the windings. This is just a guess as you have given no information about the design of you fan.
Les.
wayneh
Joined Sep 9, 2010
18,162
In my car, this is because the speed control knob is not a pot, it's a rotary digital switch. The speed is controlled by a computer that sees the number of clicks from the knob and adjusts the fan speed to preset levels. The design has always bothered me for the reason you described - poor fine control at low speed.
hp1729
Joined Nov 23, 2015
2,304
Cost? Simplicity?
How much current does your fan draw compared to less than one Amp for a light.
