Why does this MOSFET control circuit have an enormous DC current offset?
wayneh
Joined Sep 9, 2010
18,178
Check your gate voltages against the source pin voltages. Both MOSFETs are fully on all the time. I'm surprised there's any current variation at all, so I must be missing something.
Alec_t
Joined Sep 17, 2013
15,158
When posting queries about circuits being simulated in LTspice it is always helpful to post your asc file.
A1 doesn't need a ground connection and works with logic hi =1Volt unless you specify otherwise. Check the Help.
Bordodynov
Joined May 20, 2015
3,431
Why are you aggressively trying to simultaneously open (close) transistors. In real life, you will burn something. By the way, using the Alt key you can output power. Output the power of your transistors on the diagram.
Luna Tuna
Joined Jan 17, 2019
17
What do you recommend I do for an induction heater circuit that incorporates the RaspberryPI for heat control?
Luna Tuna
Joined Jan 17, 2019
17
Yes, I set these to Vhigh=5V or w/e when changing logic levels
