@Dave Lowther@TeeKay6,
I'm not going to have time to do item 6 (extreme cure) today. I'll do that tomorrow. I've done 3 (trace of C2) and 5 (remove board from grounded lid). Traces are in the attchment LogBook-Vol06-NoninvOscillationV3.pdf fig40 and fig41. The ground plane removal made no difference. There's some photos fig42, and a bit more info in the attachment.
Best regards
Dave
Thanks for the update. A couple more things that we now know are not significantly involved in producing the oscillation. Thus far, all data indicates simple capacitive coupling from pin1 to pin3 leads & components.
Another thing to consider: If in normal use you will be using coax at JP1, it would still be worth knowing how much capacitance from JP1:1 to :2 (without coax) is required to kill the oscillation. How does that value compare to the total capacitance of the coax you intend to use to connect to JP1?
Assuming that we ultimately eliminate the oscillation, I did notice a couple of graphs in the LM4562 data sheet (Fig107, 108) that indicate some sensitivity to even light capacitive loading on the output (pin1); I believe that adding a resistor in the connection from pin1 to JP4 is warranted; perhaps 100Ω (short lead to pin1), value dependent on how connection is made to next stage from JP4 and loading by next stage. This also indicates that care must be used in determining connection of the next stage.
