Why do polarized caps explode when you reverse the current?
A Homeschoolers Workbench
Joined Jul 26, 2016
142
Why do polarized caps explode?o_O
Theory one.
When someone reverses the cap the water inside the cap turns to HHO (video on it) and then explodes. theory from qoura
Argument against it.
From what I know, they do not use water as the electrolytic.
Theory two.
When someone reverses the cap it shorts, and then the heat generated from the short builds up pressure & then pop and the confetti comes out.:)
A.H.W
AlbertHall
Joined Jun 4, 2014
12,638
Theory two is right. The reverse current breaks down the insulating oxide layer and large currents start to flow which generates heat. The electrolyte is a liquid solvent (water or organic) which boils and generates high pressure - BANG.
It explodes because it becomes a low value resistor that dissipates 'real power instead being of a capacitor that stores energy. The mechanics could be a combination of vapor pressure and/or electrolysis but usually a simple boiling of fluid into vapor explains most of the pressure.
BR-549
Joined Sep 22, 2013
4,928
Ionization causes heat. Different materials have different heat expansion rates.
If the leakage current causes ionization (lot's of leakage current doesn't).....depending on that rate.......the cap can swell over time....or very quickly....i.e. explode.
Ionization can also manufacture gas. H gas would be easy. No H2O required.
